So i swapped out injectors on an 03 5.9 3500. Truck is completely stock. Driver heard 5 loud clunks from engine and then died. Any thoughts before i open her up. Followed all torque specs for injector change.
Check to make sure the pad on one of the rockers didnt fall off its just a plastic peice that slips on the bottom. Had that happen when I put my studs in. Or your exhaust is set too tight I would think.Yes i did. Now a new problem developed. I have adjusted valves twice. And when the owner drives it develops a lope in the exhaust note. Any ideas?
If you put all the rockers back in the same cylinder and the pads are all on the rockers you should have zero problem I didnt have to readjust when I did my studsOk. Ill check the exhaust lash again. Im at a loss. The plastic piece on the #1 exhaust came off. Now trying to dial it in. Checked valves and it is tight on all of them and the adjustment nuts were never touched
