1 - 11 of 11 Posts
I have a 94 12valve and I was pulling my injection pump to fix a timing issue and replace a cross threaded fuel inlet and as I was removing the injection pump but some how my lock washer dropped into the gear cover. If I’m unable to retrieve and have to pull the gear cover is there an easy way to do that?
I suppose you could try a magnet on a string. To be honest with you though pulling the timing cover isn't a big deal. Have you had it off before? If not, a KDP tab is a good excuse to open er up. Also if you have a leaky front crank seal you can take care of that as well.
Sorry, misread your post. To pull the timing cover unhook your battery's, remove the rad overflow tank and hose. Then pull your belt off and unbolt the rad shroud and fan and remove them together. Then take a picture of the crank sensor to see how it goes back together also it has to be set at a certain gap, I think it's about .050". Then unbolt the timing cover and gently pull it towards the radiator. From there you will see the KDP and hopefully the washer. Lots of write ups on that just google "KDP fix'. I would recommend a new timing cover gasket and front crank seal while you're in there. Make sure to clean the Injection pump gear and shaft very well, I use starting fluid and compressed air. Then torque the nut on the injection pump, and torque the cover bolts to 18 ft lbs
Need to pull the harmonic balancer as well before the timing cover and it is helpful to have a barring tool which are available online
I’ve never pulled it before was hoping to avoid all that work but I guess there’s no way around it. Thanks for the information I got my work cut out for me this weekend.
You'll be fine, I'm new to diesels and it would be a casual afternoon for me to get it done.
Should I use any RTV with the gasket? And do I need to buy a new KDP? I almost got it done but I ran out of day light.
I didn't use rtv personally no. It's not the KDP but the tab that holds it in. Is your kdp missing? Mine was poking out a bit but not much.
Discussion Starter #9
To be honest I wasn’t even able to get the timing cover off yet. I got off late and was only able to pull the fan, fan cover, belt and I was working on everything else but I lost day light.
That's a good start. Getting the harmonic balancer off without a barring tool can be interesting. Probably lots of tricks out there. I think I used the old bump the starter method my first time. Kinda sketchy but it works. Then to torque it on requires a bit of screwing around as well.
If the pin has fallen out, or been removed, then yes, you'll need a new one. If it's been tabbed, or it's still hangin' in there, then no, the old one is fine. If it's fallen out and you got lucky and it didn't break anything on the way down, you might be able to fish the old one out of the pan, but there's not too much room to get a magnet down there and it's probably in the rear (deep) part of the pan anyway...
1 - 11 of 11 Posts
