1 - 2 of 2 Posts
Description: Super PhatShaft 62
The Super Phat Shaft 62 was designed for trucks that have multiple fueling upgrades used to tow large loads. It features a 62mm extended tip compressor wheel but what makes the Super Phat Shaft 62 special is the 71mm exducer exhaust wheel and modified exhaust housing. The wastegate has custom dual oversized passages and a wastegate spacer plate for maximum effiency. Like all Phat Shaft turbochargers it is equipped with dual grooved bearings and an adjustable boost elbow. The Super Phat Shaft 62 can support up to 600hp. Cost: $1850.00
Keywords: Industrial injection, turbo, phatshaft
Auto part Carburetor Automotive engine part Automotive super charger part Engine
Discussion Starter · #2 ·
great turbo, well built. outperforms my friends truck same as mine with a pdr s300 custom. don't know how it is on a stock truck as i am running ddp 150's but i haven't had egts above 1150*
Rating10
Prosgood spool up, great power
Conshaven't figured any out yet
Would you recommend?yes
1 - 2 of 2 Posts
