My buddy hit me up the other day with a question about his truck. We both have 04.5's with the NV5600. He told me he was having an issue where his blower motor was being inconsistent...Ie he would turn the truck and it would stay on, until he got real aggressive with jiggling the ignition. Then it would finally submit and turn off. He said it seemed to be getting worse too. So I hopped on the forum since I haven't personally experienced this in my truck, and wow...there are a LOT of threads on this issue. People replacing ignition switches all day with no fixes, etc. After fumbling through a lot of worthless dead end threads, I found this, which was perfect for fixing the issue:
www.cumminsforum.com
The thread above was a huge help in solving the problem and we performed the fix to my buddies truck. Now, I haven't had any symptoms or anything to tell me that this would be an issue, but with how many horror stories about this poor electrical design and the potential hazards it could cause, it's a no-brainer to catch this now and prevent something like an electrical fire.
So I wanted to do a complete write up, since the ones I found were either half done, died out, or had no images. I'm not reinventing the wheel here, just putting together a better package of instructions and a wiring diagram that I made that can help others.
The background, in a nutshell, is that Dodge sent the power for the blower motor through the ignition switch. There are a series of radial "relays" in this switch. The blower motor can draw a LOT of amps...especially if it's turned on while you start the truck. So it's always a good idea to keep it off when you start if you haven't done this mod. Anyway, this high current draw (Dodge sends 2x 10 ga. wires into 2 terminals of this switch, one fused power line, and the other out to the blower) combined with the poor connector design can cause high resistance at the connector. It melts the connector and even the wiring sheath! My buddies had melted back from the connector a good 2" or so.
This is his connector:
Ok, no more background info, here's what we want to do....
Remove the power wire and feed power to blower from the connector, and run it through our own relay capable of handling the amperage (tried and true relay design, not the shotty dial relays in that ignition switch) and tap one of the ignition wires to trigger the relay, depending on when you want the blower to run.
You don't need much for this fix.
Remove the rubber handle from the tilt adjust by just pulling in the direction of the arrow:
There are 3 T-20 torx screws to release the 2 steering wheel cover halves, remove them:
The halves will now just separate, be careful with them, they're flimsy:
Remove the 2x clockspring plugs:
Remove the bundle plug from it's hole in the steering wheel tilt bracket:
You can now see your ignition switch and have access to the connector. On the lower side of the switch, you can see a red tab (look in photo above, you can see it to the left of my finger). Release that to the passenger side. The come on top and GENTLY pry up the white locking tab to get it started enough to get your finger in there. It's fragile so be careful:
While you continue to pull up on that tab, pull the connector towards the front of the truck to release it from the switch. You can see the blue face of the connector:
Continued next post...
DIY fix for intermittent or no blower fan control
If you are experiencing problems with your fan control as I did such as fan not working at all, intermittently, or fan stays on when you turn the truck off, here is a fix that will cure it. The factory ignition switch is the culprit and when I called the dealer I was informed there are close to...
- Relay rated to 40A, 4 pin (Jump to Post #3 to see my relay of choice, if you want to mount it in a convenient location)
- Length of 10 ga wire
- Length of 16ga wire
- Connectors, shrink tubing, solder, taps, however you want to make your connections.
