The lift pump will only run for a couple seconds if you just turn the key on, unless the grid heaters are cycling then it stays on longer. You can make the lift pump stay on for 20 seconds by turning the key to the on position then bumping the starter (not trying to start) and leaving the key in the on position. It would help get you answers if you would fill out your signature so that people know what year and mods you truck has.
