If you didn't get any fuel out of the injection pump it might be the problem.
Does it stay up?yeah... I pull the actuator up everytime before i try to start it... when i turn the key over the actuator doesn't go up on it own...
If you loosen the OF valve and crank the engine you should have lots of fuel. If not, you have a supply problem. If you do have fuel at the OF and none at the injectors, you have an injection pump problem.
