I just ordered a SPS62 turbo for my truck. I was wondering if I will still be able to use my BD exhaust brake with this turbo? Also I was wondering if I needed an HX40 down pipe with this turbo on my truck?
should be able to... with DP modification. Most aftermarket turbos for the 3rd gen set up use the L flange when speaking II terms, so if you bought a DP you will have to make some modifications to get it to hang right..... but the brake will work fine with that turbo.
sounds good, and yes I did get a HX40 DP to put on.
OK, the L Flange is the CR 5" flange and the HX 40 is 4" Vband.... you might need to do a little fabbin or call the brake mfg to get a housing.
ok, thanks for the info.
