Ok this is just curiousity. If I wanted to try and hit 600hp what size injector would you run 200s 220s? It seems to me that the BD towing twins that I have are good for 200s. Still streetable and still capable of towing. With electronics turned down of course. I would have to consider one power adder on top of fuel to make it. I think I would go the water/meth route, because I could use straight water to help keep egts in check while towing if they do indeed get out of hand and run the meth when playing and or dynoing. I currently can't can't break 1150* on a all out flogging with my 150s and towing what I tow on the worst grade we come across I peaked at 1100* on one small section but ran most the way at 1050* while only pushing 40psi of boost so there is some room to grow. What do you guys think it would take to get it there? Is it possible with the mentioned setup? I know I will need to do the head if I continue to push it and I have the funding set aside for it. I set it aside when I did the twins in fear of it popping then but so far so good at 56psi. And of course I will need to switch pumps in the long run to a SO or something else. But this one works fine now and until it breaks or I can't stand it anymore I am running it while I get all the other ducks in a row. If I do go the 600hp direction. Let me know what you think thanks in advance.
