1 - 10 of 10 Posts
I changed my stock injectors and crossover tubes. And it seems to idle differently now. .093 tubes and 100hp industrial inj. injectors.
It will idle normally then suddenly make a lope like noise for about 2 seconds, then idle normally again. It will also do this sometimes as I release the clutch taking off from a stop. The truck runs very smooth though when driving it or getting on it hard.
Ideas? or normal?
Put the stock tubes back in and get your money back for the bigger tubes. They arent going to do anything for power, only make your truck a headache to deal with during idling.
I have a 98.5 and just did 75hp Industrial injection injectors and bigger connecting tubes. it's idle sounds like less exhaust sound and more valve/ motor noise
I like it just not all the attention my truck gets with everyone wanting to hook to It and race
If you Google "Reset dodge Cummins APPS" you will find:
Remove negative batteries from both batteries for 30 minutes
reconnect batteries
turn key to ON position
SLOWLY press accelerator pedal to floor & SLOWLY release.
Turn key to OFF position
Done.
You're still going to have loping, due to the unnessecary oversized tubes...
Ed
Reactions: cummins6sp5.9
oh okay, I always unhook my batteries when I work on my truck I just never have reset that Apps. Go to know though
1 - 10 of 10 Posts
