1 - 11 of 11 Posts
Hi, new to the forum here. I got a 93 Ram 250 of course with the Cummins. I changed the governor spring and now the truck idles around 500rpm which is lower than when i first got it. I was wondering if it was okay to leave it there or if i should bring it back up to 700rpm?
if your oil pressure is ok, but i agree with gary, i'd raise it
Ok thanks for the replies looks like ill be bumpin it up in the mornin
You guys that have idle at 500 RPM all have manuals? My truck is shaking like a dog trying to pass a plum pit at 500 RPM...
Mine idles at 750 RPM cold, 600 RPM warm...
Why'd that be? It's a function of low combustion chamber temperatures and insufficiently atomized fuel...
I would think that the better flow of a CR engine would cause chamber temperatures to drop faster at idle and stay lower, but I would also think that they would atomize better at idle. Compression's the same, right? Higher compression would help prevent wash, I'd tend to think.
I like my idle up. I have mine at 825 warm and it runs smooth. I can't stand a low idle with a auto. Shakes the trim screws right out. It still goes into gear without a bang at 825.
1 - 11 of 11 Posts
