1 - 4 of 4 Posts
How does one tell if a 12 Valver has OEM or Aftermarket Injectors ???
Discussion Starter · #2 ·
How do I tell if my truck has aftermarket injectors ?????
Tech Specialist
The #s on the side of the body should tell you there original application if they had one, but if someone has modified a set of cores the only way to tell what they are is by using a pin gauge and/or boroscope
Discussion Starter · #4 · (Edited)
I'll look for some #s.
I bought the truck off a dealer lot and they gave me the PO's phone #.
The PO was REAL tip lipped about any mods he did to the truck. I believe he knew there was a problem brewing with it because the truck blew a head gasket (2) days after I bought it.
I can't imagine my truck having OEM injectors with all the other mods the PO did to it.
Also, I believe the dealership "De-Tuned" the AFC after they repaired the headgasket. I turned the Star screw out the other day and it came ALIVE.... BIG TIME !!!
1 - 4 of 4 Posts
