Where is the IAT sensor on a 2004 CR? Also if this is burnt up, or ruint, and needs replacement, is it possible that it would throw a p2146 code(bank 1 injectors shorted high/low) code, because my truck will run crappy when she is cold, on a cold start, then when she is hot about 175*-190* on the thermostat she will idle normal. Is it possible the IAT could cause this code because we have tried EVERYTHING else possible, checked injectors 0 ohms, replaced wiring, replace harness(s) checked the ECM nothing is out of ordinary BUT my IAT sensor IS bad.
Thanks:thumbsup:
BTW I do have a K&N filter on there if that helps, the FIPKII
W4UO
That thing still not acting right?
No its not, im pretty much running out of options, how is the fooler/RPB combo treating ya
W4UO
No No No my friend i just reprogrammed it . It now a Triple Dog. Lol so easy too.
I tell you how some companies sleep at night selling some stuff for what they do is beyond me.
Ill pm you and tell you what i did.
