1 - 20 of 28 Posts
What do yall think will be the best Vp44 for my truck.I want to be at 600hp one day.
G
you mise well go with a monster or the dragon then you can have 600 untapped but you can do 600hp easily with a tapped sovp and its half the price
PM Gus at FBD... I think he definetly has the cheapest aftermarket VP on the market.. not much more than a stock replacement if not the same price depending on vendor.
It's got 12 Valves...
Well if you have the money and want BIG power I would say go with the MONSTER..however I am starting to hear good things about the II VP and that might be a good way to go. But the Monster has proven to make high HP so like I said if you can afford it that is probably the way I would go :headbang:
I thinking about the Bd pump or the Drangon Flow.But dont no which is better to go with
Or either a Sovp44.I dont want another Hovp44
standard so with some sweet pump mods and you are there easy.
what are these sweet pump mods u speek of?
Hemi
You will prolly notice alot with anything since your coming from that stupid H.O.
How can you tell if its a s.o. or a h.o.?
not to high jack but im about to go test drive a 99 2nd gen with 125xxx miles what should i look for to tell if the vp44 is going bad or if it has some life left?
no gauges now what???
Hemi
There is a way to check it but I'm not sure. I'm pretty sure mopar1973man will know.
1 - 20 of 28 Posts
