Heres the scoop, Ran my test got everything into the reactor, let it mix for 3 hours then let it settle for another 15 hours. I then went to drain off the glycerin and nothing, there was none. Just kind of dark oil?????
I dont have a clue on what to do next....I put a small amount in a mason jar and dropped a few drops of phenol red and the mix turned bright pink.
Should I continue to let it settle or mix it some more?????
any help would be GREATLY appreciated!
So you got nothing??? You dumped in the chemicals and mixed it all around and had no seperation??? Were your heating? What is your reactor?
How's it going on the problem?
i think that we have a wasted 60 gallons of bio. Everything gelled very bad, I heated the so called biodiesel and it bubbled and foamed extremely bad. I have come to a conclusion that I think there was a ton of water in some of the oil. Of course I didnt heat the oil prior to putting it into the reactor.
Also, I tried putting some in my drying tank and it is nasty Gel crap.
So we scrapped it and are going to start another batch tonight.
Tech Specialist
Maybe you could take a scoop of that "bio-gel" and scoop some off into your tank and use it as solid fuel? like a rocket?
just kidding....but I do hope you get the kinks out and get your bio processing up and running. You know I couldn't pass up such a tempting opportunity.:rof
:lol3:
Good luck and don't let a bad batch get you down!!!
:thumbsup
Tech Specialist
On a more serious note, maybe you could try with smaller batches until you get it all worked out. 60 gallons is a lot of waste oil to be throwing away.
go to this site and make these small batches first
World Famous Dr Pepper Technique (Pat Pend) - Topic Powered by eve community
Did you heat your oil before adding methanol lye mix ? I have been making it for 2 yrs and all ways have had a good reaction. The best advice I can give is use a good quality oil I use the same oil to make bio that I run in the truck It looks almost like new oil.I cold filter it to remove all the solid oil-lard.I heat the oil to 130 to 140 and add methanol mix. Then mix for 2 hours.let settle for at least 2hrs most times over night then drain glycerin. I drain off the the pump and lines when I let it settle and put that in a quart jar then you can see what you have and you should see the glycerin star dropping out in a few minutes.I have let a mix of glycerin and bio about 50 -50 in a bucket for a week and it will keep reacting and make a lot of glycerin do not know why but it does.
