1 - 19 of 19 Posts
And I have absolutely no intention of repenting. :) Ever
AutoCal, EFI Live, one of them. Or both. Don't know, don't care. No box, single tune. He said it was 60 horse towing tune. whatev
EGR deleted and gone. 5" Turbo-Back stainless Flo Pro with muffler. Don't like the tailpipe sticking out, though. Looks like butt. Thinking about a tip but the tailpipe already sticks out far enough. I would think I could slide the Exhaust Tip on quite a ways. Looking at one from Sinister. Don't need to be taking out bicyclists in our 'hood.
He told me to drive it easy for a while. A week or so. No exhaust brake. Don't get on it. Stop and go is more gooder, he said.
The transmission seems to stumble in the lower gears and the lockup function seems uncertain of itself.
I pulled into some traffic, taking it easy, and I wasn't sure but I though I might have been turning the tires. Or the trans was stumbling. Again.... whatever.
It's a little loud at first. The Dear Wife thinks she can smell diesel exhaust. I think so, too. But I like the smell of diesel exhaust. I used to stand behind buses in the City because I liked it so much. The DW? Not so much. But that's why she's got her own car.
Then my buddy (more like a good, solid acquaintance), who did all the work, called me up last night and told me drive the snot out of it. He's the one that did all the work, so....... I don't know. I think he was drinking. A mecahnic on a Friday evening at 8:00PM? Never heard of such a thing.
So anyway, I like it. It is bada$$. It has a lot more power. A lot. I'm babying it right now like I was told but I can tell -- It's bad to the bone.
But on the highway? Purrs like a kitten. No louder than bone stock. Only in the lower gears when starting out
68rfe? Who’s tune?
The 68rfe has a 30-50 mile learning. Drive up and down no more than 30% throttle. No hwy driving or sustained speeds. Get it to shift as much as possible. Then enjoy the power.
Discussion Starter #3 (Edited)
68rfe? Who’s tune?
I did drive it on the Interstate for about 7 or 8 miles on the way home today. But that was between long-ish drives in stop and go traffic. Hope that doesn't hurt anything.
Oh man, it's got a big set now. I'm not even trying. Gotta get out of it.
I'm trying to do stop and go but sometimes... It was 100 degrees yesterday. Literally. And 100 degress in the humidity of South Florida is no fun. Plus, it was almost Friday evening rush hour, 4:30PM. So I wanted to get off the road.
Not counting the freeway drive, I've got about 40 miles of stop and go right now.
Don't wanna go out right now. People are coming over from Miami like crazy and they can NOT drive. Had a car pull right out in front of me..... Twice today.
Maybe tomorrow or the next day when they all go back. We can't catch a break down here.
Hope they don't lose power over there. Otherwise, they'll stay here
I did drive it on the Interstate for about 7 or 8 miles on the way home. But that was between long-ish drives in stop and go traffic. Hope that doesn't hurt anything.
I believe it’s using the relearn to figure out clutch material left and how hard to apply when shifting.
Straight from ctt
If your 2010+ Ram is equipped with the 68RFE automatic
transmission, you must perform a re-learn procedure each time
the ECM is flashed, even if you aren’t loading transmission
tuning. Failure to do so will cause premature transmission
failure. To perform the procedure after the ECM is flashed, drive
the truck and apply no more than 30% throttle for at least 25-
30 miles. It is important that the transmission shifts up and
down as much as possible during this period. NOTE: The 25-30
miles is to re-establish the CVI values. It is common for these
transmissions to take 400-500 miles or more to settle
down. Sustained highway speeds should be avoided for the first
25-30 miles. If you purchased a tuned TCM for your 2007.5-
2009 68RFE equipped Ram, you must perform the same relearn
process upon installation of the TCM.
I drove 15 miles home last night; mostly stop and go with some 50MPH stints in between. Went for a ride this morning and went 18 miles before I got on the freeway for the shot home. The another 6 miles stop and go home.
I’m sure your fine. I tend to over think the sh!t and try follow it to a tee.
And when I picked it up, the guys had burned through almost a quarter tank of fuel so I'm assuming they took it around the block a time or two. Hope they weren't letting it idle. I doubt it. They're pretty professional.
Hopefully they didn’t give it the fuel to test it out. That’s how the damage happens
Cut the exhaust back a few inches and put a tip on, it’ll look a lot better then being able to see the exhaust pipe inside the tip.
Reactions: RamHunter18
Discussion Starter #11
Yeah, that's a concern. Too late now. You would hope they'd know better.
Discussion Starter #12 (Edited)
Thought about doing that but not sure if I want to tackle that much stainless steel pipe with a hacksaw ;)
It's large :(
How about painting the inside of the new tip and the outside of existing exhaust pipe black? Or, much more likely to happen, just the outside of the exhaust pipe??
If it was recessed a couple inches, I don't think anybody would pay any attention to it.
I'm just wondering if I can extend the tip put by 2 inches. Might be impractical. Have to wait and see.
Discussion Starter #13 (Edited)
Here’s mine with mbrp tip. Unimpressed with how the black is coming off though
That's why God invented spray paint.
I like the look, sans the road dirt. ;)
I'm looking at chrome. I'm old biker and, to me, you just can't have too much chrome.
Found this one --
$65 on amazonian
Just wait until you see how clear the oil stays.
There is definitely no more dead pedal. I got use to driving around avoiding confusing the truck pulling out into traffic. You guys know what i am talking about. Pushing the throttle seconds before you actually need to move out. Then easing into it as hard and as fast as the computer would let you but not too far.
The edge between some decent acceleration and a pedal on the floor and a truck sitting there. Then at the last moment before you bail on the merge attempt it goes making you look like a fool to everyone in the intersection wondering why you didn’t take off when the window of opportunity was ideal.
The computer knew you were calling for power then it calculates the fuel needed to spin the turbo but not so much fuel it smokes into the DPF, makes a quick call to the EPA. POWER DENIED. You then grabbed the wheel and stick your head between your legs to kiss your a$$ goodbye as an 18 wheeler barrels toward you at 75 MPH.
Now when you call for power you get it RIGHT NOW. The truck will light up all four rear tires now and gets some into traffic.
There is no way i will have another DPF truck. Ever. Never knew what was missed. These trucks are beasts. And the exhaust sounds. Wow.
But, it voided a warranty LOL. So i cant get work done at the place that cant do oil changes right and lies about everything. No loss there. Guess FCA wont be able to find anything to weld on now.
Discussion Starter #17
Do these tunes normally change or eliminate the 'torque management' ?
Torque management is gone along with anything that could limp the truck. Depends on your tuner though. Also, there is no speed limiter anymore. All limiters are removed. For this reason i let the truck warm up fully before giving it too much pedal since fuel backdown is gone. But, if i remember correctly nobody gets full power in the first three gears stock. Unless your tuner disables that. Mine is gone and will stripe the road with all four Cooper maxx st tires. Also, tuning throws more fuel at the truck at takeoff and gets rid of dead pedal. It is much safer when the truck responds RIGHT NOW instead of calculating the most environmental way to leave a stop and pull out onto the highway where everyone is already doing 85. Your safety is not the first priority with stock tuning. Torque management and emission tuning is criminal and dangerous. Especially when it is so unpredictable. You have to ride the razors edge, during emergency maneuvers or takeoffs, and if you go too far the truck is sitting there half way into an intersection or not responding to the throttle when you need all the acceleration you can get. Keeping the dpf from loading up too quickly is the stock goal even if you get killed on the factory tune.
I never knew how much i hated the burning piss smell. With it gone the kids don’t get sick around the truck anymore. It was an asthma trigger for two of my kids. I use to have to take puke cans with me incase a regeneration started and the wind was blowing the wrong way if the kids were with me. Also, i would need their nebulizers. The tuning has eliminated that mess completely. I can actually use the truck more with the family. Thats the best win i could have asked for.
I cant even make the truck smoke on purpose with the +75 tow tune. There is a slight barely imperceptible puff when i get into the most ideal smoke situations. Even then it clears right up. There is no way it will draw attention to the truck. There is zero soot on my bumper or dually flare. Even with a small muffler there is no drone. It is as quiet on the highway as before. Honestly i wish i could hear it more while driving. The idle rumble is amazing though.
I am about to return to stock for the inspection then i will remove the grid heater plate, as of now it is unplugged, get a new intake horn in preparation for water meth to help clean up the residual egr soot. And, then i swap the turbo and add a steed speed manifold.
Discussion Starter #19
Good stuff, thanks.
But remember, we should listen to our betters in the goobermint. Afterall, they're smarter than we are. And not afraid to tell you that, either.....
Has there ever been an almost cabinet-level position (they'll formalize it as soon as the next moron d gets into office) that is almost totally Anti-American??
Didja know that the EPA's government workers Union just endorse Rashida Tlaib for Office? How patriotic is that???
And all these crackdowns on Tuners, etc? It's to show you who's boss. They're telling you Deplorables straight up who runs the Country (hint; it ain't the voters, it's the permanent bureaucracy)
Not a lot we can do in the short term. Vote, that's about it. Those EPA employees? The ones they actively recruit from the Peace Corps, the Sierra Club and activist College Campuses..... They get tenure after 3 years. Then they work hand in hand with EnvoronMENTAL groups.
Like this -- They enter into a handshake and a wink agreement with somebody like the Sierra Club. The Sierra CLub files suit over something and the EPA and them already have an agreement written up when they go to Court. The Court approves it and -- Voila!! New Law is in effect.
And where do those environMENTAL groups get their money?
During the LCinC's term, they filed a lot of lawsuits against Companies for breaking their Pixie Dust Laws.
When they lost, they were often fined Millions of dollars. Sometimes HUNDREDS of millions.
And the Companies could receive a huge 'offset' in the fines if they made HUGE 'charitable' donations to these 501(c)(3) environMENTAL groups.
It's a shakedown.
Elections matter, people
end rant
1 - 19 of 19 Posts
