1 - 20 of 31 Posts
why why why...why is that my tranny likes to hang in gear when driving.... 1st to 2nd is fine 2nd-3rd is ok most of the time but 3rd-4th it takes forever to shift :banghead:..wtf.... when you get on it, it shifts fine... when i am just cruising it does that BS.... why why why...sorry i am really frustrated...thanks in advance
funny you mentioned that, my 07 5.9 seems to do the same thing, I noticed it when it got down into the teens or single digit temps (ohio), around the same time I also downloaded a BD TD PP and played for 10 mins (on friends suggestion), then unloaded it, trannys "hung up" in the 3-4 gear shift since, Cold weather? or Downloader? or am I just looking for a reason to think somethings wrong?
How long was the truck setting? I usually let the truck idle in neutral for a good min or two before I take off and I don't get on it until it's up to normal op temps. The fluid will settle down to the bottom when not in use and is cold as well, which will cause hang ups and miss gear events from my experience.
What rpm is "forever"? Are you in OD when it does this? Have you tried TH for comparison?
Also how many miles on the truck?
unless you want to build your tranny- I would suggest the shift enhanser from DTT.. and the GM GOV pressure solenoid:thumbsup:
Build tranny = ALOT of $$$......shift enhancer/gm solenoid = ALOT less $$$
Texas Pipliner
It sounds to me like the pressure solenoid or the sensor is going out of the transmission. You could always upgrade to the GM Governor solenoid from Borg Werner and replace the sensor. The shift into overdrive is controlled by these sensors and solenoid.
Discussion Starter #9
When it shifts from 3-4 it hangs at around 1800-2100 rpm for about 3-4 blocks. What is a TH comparison? 84500 miles on truck with about 3000 on rebuilt tranny. Do u think the Borg Warner upgrade will fix this problem.
Texas Pipliner
I'm no specialist or anything but my brother had this same problem and it was the sensor in the transmission.
Discussion Starter #12
Its been cold here in Vegas but it does it in the summer and It will do it all day long. Thanks for your input
Discussion Starter #13
Do you know what sensor? Can yu ask him. Thanks in advance.
Texas Pipliner
This is what I found in the forums it has the pressure and sensors in it. Their is a lot of information on this fix just search the forums their are a lot guys on here much more knowledgeable about this problem than I.
SUBJECT:
48RE Transmission - 1-2 Shift Hunt At Light Throttle
OVERVIEW:
This bulletin involves the replacement of the governor pressure solenoid valve in the
transmission valve body.
MODELS:
2004 - 2007 (DR/DH/D1) Ram Truck (2500/3500)
SYMPTOM/CONDITION:
The customer may experience a 1-2 shift transmission hunt during light throttle application.
This condition may be due to a governor pressure solenoid valve.
DIAGNOSIS:
If the customer experiences the above condition perform the Repair Procedure.
PARTS REQUIRED:
Qty. Part No. Description
1 04617210 Valve, Governor Pressure Solenoid
4 05013457AA ATF+4 Automatic Transmission Fluid
AR 02464324AC Gasket, Transmission Oil Pan (Note: Original pan
gasket is reusable and should not require
replacement).
REPAIR PROCEDURE:
1. Raise the vehicle on a suitable lift. Turn the ignition switch to the “OFF” position.
Remove the ignition key from the ignition switch.
2. Remove the transmission fluid (oil) pan and pan gasket. Clean and save the pan
gasket for later use during reassembly.
3. Disengage the wire connector to the governor pressure solenoid valve (Fig. 1).
4. Remove the screws used to secure the governor pressure solenoid valve retainer to
the transmission valve body.
5. Remove the old governor pressure solenoid valve from the transmission valve body.
6. Clean the transmission housing and oil pan gasket surfaces.
7. Lubricate the o-rings on the new governor pressure solenoid valve.
8. Align the governor pressure solenoid valve to the bore in the valve body.
9. Install the governor pressure solenoid valve to the valve body.
NUMBER: 21-009-07
GROUP: Transmission
DATE: May 24, 2007
10. Install the governor pressure solenoid valve retainer and attaching screws to the valve
body.
11. Connect the wire connector to the governor pressure solenoid valve.
12. Install the transmission fluid (oil) pan and pan gasket (saved earlier) to the
transmission. Tighten attaching bolts to 13.6 Nm (125 in. lbs.).
Fig. 1 Governor Solenoid And Pressure Sensor
1 - GOVERNOR PRESSURE SENSOR
2 - GOVERNOR PRESSURE SOLENOID VALVE
3 - ELECTRONIC GOVERNOR
13. Lower vehicle.
14. Add automatic transmission fluid to the transmission.
15. Verify correct transmission fluid level.
POLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation No: Description Amount
21-96-05-90 Valve, Transmission Governor
Pressure Solenoid - Replace (B)
0.7 Hrs.
FAILURE CODE:
ZZ Service Action
21-009-07 -2-
Who rebuilt the tranny? I had Chapman Dodge rebuild mine here in Vegas and it still does the same thing. I have also had the solenoid replaced 5 different time under warranty......still does it, but it seems better in tow haul mode.
Discussion Starter #16
The extended warranty sent out a brand new rebuilt. I forgot who they got it from. But chapman did all the install work. After it was installed the gov pressure solenoid went out (surging in low rpm when cold) and something else I forgot tho.
Discussion Starter #17
well i ordered my borg warner governor pressure solenoid today from transtar... should be here friday or monday... i will post after installed if it fixes it
tow/haul comparison
1 - 20 of 31 Posts
