A lil backround.. i was just onmy way home from work 27 mile commute and prolly 20 miles into it on the highway my truck just flattened out... NO POWER like it was dead or dieing, perhaps de fueling. al guages looked good at that time nothing out of the ordanary boost 10lbs, pyro 750, trans 150, fuel press 9psi, speed 70mph, 2100 rpm smarty was on setting 3, truck has 103600 miles on it and i replaced the lift pump when i bought the truck (under warrentee).........im not shure:HELP PLEASE
the codes i retrieved are as follows
i used my smarty to ge the codes
PO216: Fuel injection pump timing failure
PO602: Fueling callibration error normal with non stock software
P1693: DTC detected in companion JTEC module
give me all your information and help please!!! suggestions and all i need this truck to get to work....
please!!!
THANKS!!!
please!!!
THANKS!!!
