Hey...
This is my second post, following my introduction...
If you believe its a scam, please move on...
Plain and simple. I can prove that gravity does exist... I can't prove that an engine is incapable of utilizing a gallon of electroysed water to move itself a certain distance. Its already been PROVEN that any engine can run off a hydrogen/ovygen mixture.
Its my theory that, efficiency of energy tranfer is what is key.
Electralysis takes a crap ton of current to pierce through water. its liquid... in effect, its "stonger" than a solid... hehehe wrap your brain around that..
My honda doesn't have enough horsepower to power a pulley driven generator to make the volts/amps that are needed. Which is prolly why most of these hho things are scams... their alternators are not putting out enough energy to make the amount of gas needed. Efficiency is Key... We will have to sacrifice performance to make this work... no doubt in my mind... but I believe nonetheless... it can work...
I have a 4 plate aluminum cell that has HHO production with a 12v system @ about 30 amps with no electrolyte... just plain old tap water. It goes ballistic nearly doubles when I add rocksalt, the crap that rusts your car here in wonderful new york. This is without any modification to the current or circuit, no tricks to the trade... 12v and 30 amps, positive and negative held close together under water... not rocket science. I imagine if I used better/purer metal, with more attention to detail, I'd get even more.
The VIC(voltage intensifier circuit), and PWM (pulse width modifier circuit) will be tools that I believe are key to making this successfull. I'm currently building them with my handy dandy radio shack education lab I got for 70 bucks
I'm a musician, I record my band onto my computer.
I have software that alllows me to modify the WAV files for desired pitch, volume, effects... you guys know how good an album can sound...
Now think about editing the current that runs from the alt, to the battery, through the cell back to the battery. Frequency manipulation.
I started with the idea of a second alternator... but a gasoline engine requires a spark to run. A diesel does not. What would happen if you put a coil on a diesel, but made a plasma arc inside the cell, and a tiny mist of water was sprayed into that arc. What would happen? Instant HHO?
I believe this is possible. I'm looking for other people that want to discuss this, and share research.
cheers
-greg
cheers
-greg
