I’ve changed everything that has to do with the power steering, Vac Pump, PS pump, Hydroboost, lines, steering box. While bleeding it I’m able to build up a pretty stiff pedal, but as soon as I start it up I can press it as far as it will go easily.
I cracked the return line to the hydroboost while it was running and it poured fluid so I’m assuming the ps pump isn’t shot but I don’t know much about Hydroboost, out of the 5 01’s I’ve had this is the first I’ve had to mess with it
