1 - 3 of 3 Posts
So I've decided to build my own compound setup. I recently got my hands on a 80mm/113mm 25cm t6 hx60 and I'm planning on slapping a 67mm/70mm 16cm t4 twin scroll hx52 on top of it. Neither are wastgated so im plumbing a tial into the intermediate pipe for the hx60. I got 200hp injectors, a 200gph air dog and a 5k rpm 13mm p pump built to feed'em. How does this setup sound? Anyone done an hx52/hx60 build before? General opinions/experience. Thanks in advance.
The waste gate needs to be between manifold and hx52.
I think it will have too much lag and with that huge cm16 you probably wouldn't need a waste gate unless your turning 4k.
Fill out your signature so folks know what your working with.
Reactions: 2002CTD
You might want to check out this thread.
1 - 3 of 3 Posts
