1 - 9 of 9 Posts
AMM pioneer
Have you done no research on the turbo that your truck has currently? The he351 is much much bigger than the hx35 and superior to the hx40 as well. A he351 can support a very warm 500 hp run.
AMM pioneer
Unless you are producing over 550 hp, replace it with another he351. You can usually find these for 300-400 dollars in the classifieds or Craigslist.
AMM pioneer
Well with the injectors and smarty, you would be alright with the he351, but a 62mm could help cool things down if you want to upgrade to a bigger turbo.
AMM pioneer
Well it will be a little laggier down low but will flow more air and have more boost up top once spooled as well as lower egts.
1 - 9 of 9 Posts
