Can I run a HX35 with stock head bolts? If not what is a good bolt on turbo for an almost stock truck?
I do on my 12v and on my daily driver both see 40 plus psi every time I drive them for a couple 100k on my Dd now. It's a stock turbo. Imo you will be fine.
My old truck I torqued my stock bolts to 135lbs ran twins and 52 psi every day. Hx35 s400
You should be fine.
Tighten all bolts to 66 ft lbs, tighten bolts 4,5,12,13,20,21(the long 12mm bolts) to 89 ft lbs. last step was tighten all bolts 90 degrees.
Hx35 will be fine without studs.
The hx35 would be happiest if kept under 38-40psi
Sent using AutoGuide
Shouldn't have a problem buddies got a 90 model that's pushed 48. But eventually u'll want better studs
