1 - 3 of 3 Posts
Hi i just bought this hx35 turbo and i was taking the exhaust elbow off and noticed that the turbine wheel nut was almost worn in half. there’s no damage on the wheel so i’m not sure if it was done for a purpose.
906263
Hi i just bought this hx35 turbo and i was taking the exhaust elbow off and noticed that the turbine wheel nut was almost worn in half. there’s no damage on the wheel so i’m not sure if it was done for a purpose. View attachment 906263
That is how they balance them. Perfectly normal
Vendor
Yes, The turbine wheel and shaft is balanced and and the compressor wheel is balanced. Then the rotating assembly as a whole should be balanced to avoid tolerance stacking.
1 - 3 of 3 Posts
