2001 H.O. NV5600 DANA 80S bilstien 5100's hx35w e/boost elbow E/ATT/JUICE BHAF 4IN MAGNAFLOW
OK so recently I got my hands on A HX40 to build a hybrid out of my 35. 1st thing I did was separate the HX40 down to basically the turbine shaft with a compressor wheel Off. Once that was complete I went to cleaning the Turbo as best as I could and and had a spare HX35 cartridge laying around. Once the 40 was apart I put the comp wheel from the 40 onto the 35 turbine and shaft reassembled the 35 shaft and 40comp whel on to the hx40 catridge.after that i drilled and tapped the housing of the 40.once that's was done i built a bracket out of some metal I had laying around shped it with a bench grinder anvil and torch [(it was cast steel) i figured best for rigidity of the options i had laying around]on the lower forward most Turbo Stud(the mount also has a small tail that runs down the back of the flange so it doesnt walk). Once that was complete II mounted it all up here are some of the photos from the building and I'll put more more information on how it runs and once I get to drive it; but as of right now it definitely whistles a lot more I know that don't matter too much but I imagine that that means it's making more boost call me retarded I'm good with it here is the photos. Thanks for looking happy to amswer any questions
also i did not use the Chinese whirlybird exhuasthousing or turbine shaft i used genuine holset for somereason someone had put a turbone housing on a legit 35w ntsure why not that i even used that housing but i know folks here are at times critical lol thanks seemed easy in theory but all in all took two days (i took my time for fitment and fit and finish) was a fun a$$ lil project!
