1 - 9 of 9 Posts
Probably but not recommended.
Have you inspected your fan resistor?
Did you jump out your fan motor? I replaced my fan/motor some years ago.
Reactions: rghavana
I've replaced the fan and resistor, there's no power at the switch so it's probably the ignition. I just want to wire it up to the battery with a switch till spring, I now have 8+ inches of snow.... Does anyone know if the fan will run ok wired to a battery??
The control units have been known to fail. Do you know someone with similar truck that you could temporarily swap to see if its that?
Sure, I would set up a relay with a switch and fuse the wire to the fan and run a wire to a battery. It will always be on high.
Or buy the switches from a salvage yard. That will be quicker to swap out.
2006 Dodge Ram 2500 Manual Climate Control/ Mirrors AC 5056569AC | eBay
Reactions: rghavana
Relay?? And what size fuse?
If you are not familiar wiring a relay/switch, consider replacing the switch console for your year model, after pinning out the wiring from the switch to the fan motor.
Good luck.
1 - 9 of 9 Posts
