I decided to install some analog guages in my truck and was wondering if their is a fuse or a wire I can T into to have them light up with the dash lights and be able to like wise dime with them. Thanks in advance.
I just tapped into the parking lights fuse. :thumbsup:
Thanks, is that fuse under the hood or the driver's side fuse fanel.
Pull the dimmer switch.. Large gauge brown wire is the dimmed power lead. Just get a wire tap and ground them at your own location and youre done.
The one in the drivers side fuse panel is the one I used. :thumbsup:
Ok I misunderstood. You have to tap that wire that dims behind the dimmer switch as LOCO OFFROAD stated. Sorry for the mixup. :thumbsup:
cumminsforum.com
I cheated and wire into the illumination lead on the back of the radio... Since my stereo is aftermarket and I used a adapter to wire to the factory wiring I had the extra wire for panel lights...:hehe:
