1 - 4 of 4 Posts
· Super Moderator
99 qclb, 325dap, compound. Billet trans, 37 toyo, lockers, winch, 10kw stereo, quadzilla
i just bought a new battery and wanted to test it to see how it differs from my old ones. what is correct and what is wrong in this video?
Load test as he did in the video.
1/2 cold cranking amps for 15 seconds (not sure he went 15) in round numbers voltage should not drop below 9 volts during the test.
Proper testing procedure says battery should be full charged, so don't be alarmed if new ones fall close to the limit right off the shelf.
Typically a battery that is causing a starting issue will dive below the 9 volts well before the 15 second period.
As far as wrong I didn't see if he was wearing safety glasses
One big problem. The tester he's using is not a carbon pile tester. It's an induction element tester that heats a resistive coil to consume energy.
Carbon pile is the only way to accurately test batteries. I don't care what anyone says.
Sent from my SM-G930W8 using Tapatalk
Reactions: dhoagland
· Super Moderator
1 - 4 of 4 Posts
