just picked up a 05- 2500 with a auto trans/4x4 with 126k miles ,how do you identify the make model of the transmission it has and what h.p, motor you have .i know what my 16 had but going to a earlier model i am just trying to get things straight
Only one auto trans available in the 05 and one hp rating.
Can get original build sheet at
FCA RAM plug in your VIN
Should be same as sticker in glove box.
If glove box sticker missing behind left headlight, body code plate has some info.
Can verify original engine block
by Engine Serial number(ESN) on top of oil cooler mount stamped in block.
cummins website can cross vin to original ESN.
Can verify original trans
by part number/prodution date stamped on edge of case below trans range sensor.
thanks much!!
