i am wondering how to remove a 3 inch body lift
i do not have the stock mounts but is there some place that i can get them
it has a 6 inch lift already too
any help would be great
thanks
:confused013:
Pull the body mount bolts, slightly pick up the bed or cab, take out the 3" spacer, put the stock mount back in, lower the cab or bed back on the mount, put the bolt back in.
wait so the stock mounts should be under the spacer mount?
your body lift spacers replaced the stock ones, your body lift spacers are round(prolly 2" dia). the stock ones are prolly 2" high. id be interested prolly in the lift and would you include the other necessary stuff. pitman arm and shifter extensions and maybe the stearing extension
you can get them at the junkyard. (stock spacers)
