1 - 3 of 3 Posts
i am wondering how to remove a body lift
i do not have the stock body mounts but is there a place that i can get them
any help would be great
thanks
:confused013::confused013::confused013:
you should be able to just put the stock ones back in and re-do the fan shroud and be good, but others with more experience with chime in.:thumbsup:
On call 24/7
You should have the stock mounts under the body lift. If there not there then the lift wont be as high as its advertised because you loose the inch that the factory lift made. I have put a few on and you'll have to rais the cab, bed and remove fron and rear bumpers and remove the spacers or drop downs on all of them. You might have shifter linkage to remove and a steering shaft extension to remove as well. You will also need to get it aligned if there was steering extension.
1 - 3 of 3 Posts
