LP? Lift pump?The manual pump is on the end of the LP it's black with a rubber boot around it, just push it down.
Thanks, appreciated,Also there is a little 10mm bolt on top of the fuel filter that is a bleeder screw. It is on the line going from the filter to the engine.
I was trying to say it was not an electric lift pump, must manual or mechanical. It is always a bit hard on international forums, as things are often called differently country to country so I was trying to hard to be specific when i should have just said lift pump or fuel pump and mechanical. I was born in the UK, I got some funny looks when I arrived here and started taking about car wings, here they are guards I think you call them Fenders.You said you have the manual pump back, isn't it mounted on the left side of the block above the starter? If so that's called a lift pump (LP).
