01 2500 HO w/6-speed 140,000 miles all original driveline
I have the hard to shift 6 speed. Shifts fine when the motor is off but while running and not moving I often can't get it into 1st, 2nd, or reverse. While rolling it sometimes shifts ok and sometimes does not. Reving the motor between shifts helps it slide into gear. I changed the oil this summer and filled it with 6 qts of the appropriate Amsoil. I had the inspection plate off the side of the tranny and cleaned out the shavings off the magnet. There was no change in shifting after the oil change. Removed my floor mat to make sure the pedal was getting full travel.
So correct me if I'm wrong but either the clutch hydros are going bad or some bearing (throw-out?, pilot?) is bad. The clutch fluid reservoir is full and I have never added any fluid. Does that mean the clutch hydros are for sure NOT the problem? Can the hydros go out without losing fluid, or only lose such a small amount that it's not noticeable?
I don't like to just throw parts at things to find out what the problem was. How do you identify which one is the issue? If that bearing is bad does the tranny need to come out?
Thanks in advance,
Thanks in advance,
