1 - 4 of 4 Posts
I bought a truck with a six speed nv 5600. The inner indicator of the gear shift pattern was broken out. After a purchase of one, I can't imagine getting it back in the handle. It appears it must go in the handle after the handle is installed on the stick, because the jam nut needs to be locked from the top with the pattern indicator removed to accomplish this. I don't see how I can get it installed w/o either breaking the new indicator, or blemishing the rubber outer portion of the handle. It appears to be the correct replacement as what little was left of the old one looked the same as the new and the pattern is correct. Thanks.
Its hard but it will go in there. More than likely youll tear the rubber shift knob though.
On call 24/7
Mine turns as I drive, not the nob but just the indicator.
1 - 4 of 4 Posts
