6.7 Powertrain Section
Hope this answers your question. If I remember right, open the valve 2 or 3 turns, have someone turn the key on, and catch the fuel/water coming out the little tube as the system is pressured. I got messy trying to just open the valve till I got fluid, and I was not the only one.
The easy way is to open the valve and turn the key on a couple of times. You can also open the valve a bit while the engine is running but don't turn the valve very much.
Where is the valve everyone is talking about?
This is my first diesel you would think they would give you some training on this stuff. The owners manual does not show me how.
The valve is in on the left side; look through the front wheel well you will see a black filter with a clear plastic tube. The valve is light gray with a clear plastic tube attached. The filter also has a two conductor electrical connection attached.
