1 - 20 of 60 Posts
Ok this might be a dumb question.
How does every body stage for a drag race?
Four wheel drive
2 wheel drive
I know to buil boost for you get to start lane.
Iv heard all diffrent things
so i take it Four Wheel High
Dam i hop high works..I know either high or low dont work. not sure which one..looks like i wll have to go on my road and see.
Thats not good. If all else fails you can do a boosted 2wd launch and smoke the rear tires
SO:peelout:peelout
No need for burnout unless you get the tires wet driving into the lanes. If so clean the rear tires off in 2wd. Put it in 4wd Hi. First Stage, start building boost, let off the brake and 2nd stage build the rest of your boost and leave on the last yellow. Be sure to take it out of 4wd before turning off the end of the track.
:lol3:
Yeah i forgot about that the first time i went down the track. its my first 4wd and got to the end of the track to turn back and was like " what the F!" oh yeah, (click)
Drive around the water box, line yourself up, put it in 4 high, prestage and STOP. let the other vehicle go in 1st if possible, build 15-18lbs of boost, ease into stage, leave on the last yellow.
Dodge | Commins | Forum
Well maximum boost is 23 so yea
Ok this is what iv gotten
If four wheel hi works
1. Prestage
2. let other car stage
3. Build boost and ease ahead to stage
4. leave at last yellow
5. HOLD ON.
6. TAKE OUT OF FOUR WHEEL BEFORE TURNIN
I altered your post just a touch.
I slide it out of 4x4 as I am going down the track, you don't have to, that's just the way I do it.
From what i understand, it doesnt come out of 4wd until you let off the throttle and coast for a sec. am i wrong?
Well if you have a 2wd you don't have a choice but to spin!!
Standard???
what about draggin a standard???:beer
thats what i thought...there was a guy on the forum a while ago claiming that he would take it out of 4wd 1/2 track and finish in "2wd"...and when he did this, he saw consistently better times??
1 - 20 of 60 Posts
