1 - 11 of 11 Posts
97 2500 auto 4x4 8800 gvw. Is there a web site to enter the vin code or anything?
i went to deal and had a build sheet printed out, it will show all options it came with it was FREE
Thanks. Ill go get a build sheet printed. Much appreciated.
its also on the underside of the hood.
SC Chapter President
If its 4x4, you can always read the tag on the diff cover. First 3 #'s is the gear ratio. Mine starts with 410******.
Is there a code for the limited slip rear?
I may be wrong, but I think they all are limited slip. Like I said, I could be wrong.
no im pretty sure they aren't. On one of the bolts on the diff cover i think the bottom right side will have a little tag thing on it that signifies limited slip.
Mine's not limited slip but it ALWAYS burns both tires off in a burnout?? the only time just one will go is if im going around a tight corner and light it up.
1 - 11 of 11 Posts
