how hot are you running?
Your local guy isn't knowledgeable on 3rd gen turbos then. Stock is 1450* continuous. Think of the thousands and thousands of bone stock trucks pulling HEAVY loads without gauges or concern for their EGT's... They are all running in the 1400's all the time and the HE351 is a very reliable turbo.I just bought an Armstrong header from someone on this forum (waiting for it to arrive). I am interested to know if it can help me with EGT reduction. I easily get into the 1200's and have seen 1400+. My local Diesel performance guy says that these stock turbos are good for 1200 degree EGT's under continuous load, but not higher. If this header doesn't work for me, i'll be looking at adding Snow (cheap option), but then we're heading for intercooler and turbo upgrades... $$$
They don't run near as hot as the 04.5+ and the 04.5+ has some mods to the head to handle the increased heat.How about the 03-04's? I didn't get the twins on before I left, but messing around with all the fuel mods(on SW3) I did accidentally let it spike to 1400* once and almost 1500* another time. Neither were over 1300 for more than 2 seconds. I have heard 555's are bad about dropping valve seats but I assume I didn't hurt anything by doing that? Sorry not trying to hijack the thread.
To a point yes, but from what I have seen on my 05 and my dads 06 when you get up around 2600+ the EGT's are much higher.. must have something to do with the 3rd event and emissions.I think some of us tend to give complicated answers to simple questions. To answer the original Q, Running at a higher rpm for a given speed/load will lower EGTs.
If it takes lets say, 275hp to maintain 60mph towing a trailer up a long, steep grade, Your egts will be lower (as well as auto trans temp) at 2600 rpm than at 2000 rpm. this is whats called "lugging" a diesel.
I will often down shift to 5th when pulling a heavy load up a long grade even if the truck can pull it in 6th. RPMs on a Cummins dont scare me...High EGTs do
Yes I have noticed this too.To a point yes, but from what I have seen on my 05 and my dads 06 when you get up around 2600+ the EGT's are much higher.. must have something to do with the 3rd event and emissions.
This is good to know... :headbang:Your local guy isn't knowledgeable on 3rd gen turbos then. Stock is 1450* continuous. Think of the thousands and thousands of bone stock trucks pulling HEAVY loads without gauges or concern for their EGT's... They are all running in the 1400's all the time and the HE351 is a very reliable turbo.
ya she is good friend of mine.I'm sorry... I wasn't listining, I was concentrating on your avatar
Bottom of the manifold would be pre-turbo. Are you sure you don't have it in the elbow of the turbo just before the exhaust system? If its there, then 900-1000 is about the same as 1250-1400 pre-turbo.wow some guys are running kinda hot...
im only seeing a little over 900 at WOT with my smarty on sw3 and the things in my sig...is this normal? seems low...
my thermocouple is at the bottom of the manifold post turbo i believe?
The temps will be lower when the thermocouple is mounted post turbo. Your true readings will be a couple hundred degree higher. You may want to change your sensor location to be safe and see what your truck is actually doing.wow some guys are running kinda hot...
