1 - 3 of 3 Posts
Guys I just replaced my procomp short arms for the tuff country long arm upgrade. My questions are:
1) I noticed before that the pasenger side tire stuck out from the fender about an inch farther than the drivers side. I adjusted my track bar to compensate but would like to have some ideas on how to do this properly? IE measure from the front axle to the rear axle like squaring footings?
2) The truck seems to pull to the left now and follows the road crown would caster cause this, or is one arm longer than the other?
3) How do I determine if the axle is centered in the wheel well?
I dont believe replacing the arms should affect toe in or am I incorrect in saying this? I should mention that all 4 ball joints are new and steering linkage has been replaced with the new T style and then went for an alignment but have sinced replaced the short arms with the long arms.
Thanks
Discussion Starter · #2 ·
Nobody knows hey I just thought with all the custom lifts out there someone would know how to adjust the front axle properly. I sure dont trust our alignment shops we have way up here in the north, if the truck is not like it shows on the computer program the just:confused013: and :S:
· Rescue Tower
park truck on level ground, hang plumb bob over the frame on both sides and mark your axle. Measure from your mark to the knuckle. If those measurements are different then you axle is not centered on your frame.
Reactions: txpig
1 - 3 of 3 Posts
