#1 diesel fuel and kerosene (ugh) are cetane boosters.
Not necessarily. Blends of 20% or less of biodiesel fuel should result in the same MPG and power performance. Higher blends than that, may begin to impact your economy and performance.so then its a givin i'll loose MPG then?
I was thinking of two fuel sets ups,Not necessarily. Blends of 20% or less of biodiesel fuel should result in the same MPG and power performance. Higher blends than that, may begin to impact your economy and performance.
If you look at ethanol for example, it has 50% less energy than gasoline, which automatically results in poorer economy for gasser powered vehicles.
Are you serious? 2 fuel setups, like are you gonna add another fuel tank and pump? And fill each one with your special little mix? You must be wealthy, or just really eccentric.I was thinking of two fuel sets ups,
1. ULSD + 1.5oz 2 stoke oil per gallon+ Cetane Booster, MPG booster..
2. B5% Bio Diesel, plus cetane/mpg booster.
not so sure on how to work out percentages, but do you think that would be a viable solution,
DO you think B5% Bio Diesel would have enough lubrication to provide more lubrication then LSD? Or do you know roughly how much bio you would need to equal LSD?
I know a few guys that have done that an got caught cause the dot pul;led there filterI know a few guys with dual fuel setups...
Fill the transfer tank up with offroad diesel and run on that... stealth run all the lines and everything..
If you get dipped you'll pass cause you don't have any OR#2 in your tank
hell no, i mean as a viable replacement for LSD. Either stick with the current plan of ULSD +2 stoke oil, or run B5 Bio Diesel instead, im not into the whole two tank thing, this truck needs to be kept in a professional manner, so everything that is done has to be up to par and code. this means no dual tank with eccentric switch and fueling systems.Are you serious? 2 fuel setups, like are you gonna add another fuel tank and pump? And fill each one with your special little mix? You must be wealthy, or just really eccentric.
