Simple as can be.
The throttle sitting on the top front of the injection pump rests on a screw that lies in between the injection pump and the head. To change idle speed you back the screw out or thread it forward.
Simple doesn't mean easy, however. The location of the screw makes it difficult to get to; I'd recommend knocking the lock nut loose with a screw driver, dousing the thing in the penetrating agent of your choice (Liquid Wrench or Aerokroil), and then using a 1/4" boxend wrench to pry onto the end of the screw and twist it.
