1 - 10 of 10 Posts
Yes, I did do a search, maybe I missed it. How OFTEN are you greasing the front drive shaft fitting??? Every 15K with the oil change? I do oil changes every 7500 and have the dealer do the grease fitting. SOmetimes they say it needed it, others times they say it wouldnt take any grease. Thanks!
I grease mine per the manual - it is it's own item in there. If it won't take grease they didn't do it right as there's nothing stopping the grease from going out.
Above is 1,000% correct
I know it has been posted up by someone in the past, but anyone have a link to the tool/fitting one needs to actual grease that front driveshaft?
Thanks in advance
just pushed past 12,000 and still haven't done mine.......... generally I am much more on top of such things. ugh
Not as critical with the axle disconnect on the 4gen as it was with a third gen. In theory the drive shaft shouldn't be turning unless you are in 4wd.
Sent from my SM-G920T using Tapatalk
1 - 10 of 10 Posts
