1 - 17 of 17 Posts
they will be aftermarket will that be a problem? i was gonna run 18'' black rock star wheels?will i need to add a little lift?
heres a stupid question,how do i tell if my backspacing is right?
normally, you would want it between 5 and 6"s of backspacing when trying to get maximum tire w/ minimal lift...but with a 33, i wouldn't worry much about it, unless you're trying to run somewhere around 4"s of backspacing.
i'm pretty sure the rockstars have somewhere around 5.5", so you'll be fine...
what width are they? If you get something like a 18x10 your tires may rub. But if you run a stock wheel or something narrower than a 10 inch wide wheel you should be alright
Discussion Starter · #11 · (Edited)
they are 18x9s with a backspacing of 5.00'' with 33'' nitto mud grapplers you guys know more about this stuff than me thats why i came on here if you say it works im gonna do it.:yourock:
You should be fine then. Post pics when you get it done bud
1 - 17 of 17 Posts
