1 - 20 of 24 Posts
I'm buying new shocks and sway bar end links and I'm trying to figure out the best route to go. I think my truck has somewhere between a 4 and 6 inch lift. If anyone can help me out it would be much appreciated. Coil spring Suspension part Suspension Auto part Tire
Auto part Suspension part Tire Suspension Coil spring
Suspension part Coil spring Auto part Suspension Shock absorber
Auto part Tire Vehicle Automotive tire Suspension
Looks like it could be rough country coils with a 2-3" spacer on top. Rear appears to be a 2" block. So all in all, my guess is leveling springs with a spacer on top because from the looks of it, only the lower control arms are longer. Uppers look stock to me. so 5" front, and 2" higher in the rear.
So I ordered 4-6inch fox racing 2.0 shocks with the reservoir. Would this be the the correct size for the front a rear. You said 5 inches in the front and 2 higher in rear. Will those work?
There are pictures of my truck on here. Take a look and let me know thanks. I measured a 2001 dodge ram 2500 stock ground to top of tailgate then my truck ground to top of tailgate and it came out 6 inch difference. I measure the front middle part of the axle to the bottom or fender and same on rear it all came out to six inches.
I'm going to say 4.5" Seems really common on these trucks and looks like my dad's 4.5"
Discussion Starter · #10 ·
Thanks im saving up to get a bunch of stuff. I think 20 inch black xd's would look good on my truck with terra grapplers.
Those are 20's on his truck too. I think 20's look good with a 35 and a 37.
Discussion Starter · #12 ·
Thanks for all the help guys and Yea 20s look great im going for black and chrome to match my grill. Then going to get a smarty s-06 then possibly upgrades trans and work towards twins.
Right on keep us updated on the truck and upgrades.
I'm buying new shocks and sway bar end links and I'm trying to figure out the best route to go. I think my truck has somewhere between a 4 and 6 inch lift. If anyone can help me out it would be much appreciated. View attachment 126930
View attachment 126938 View attachment 126946 View attachment 126954
3GCR-
What sway bar links did you go with? I need to replace mine as well. Have a 4" Rancho kit, no drop mount for the sway bar itself. Was checking out the Maxx, Tough Country, Pure Perf & Carli links. Just not entirely sure on the size and do not want to come up short with the lift.
Thanks
MtnMan, go with a set of heim end links, they are adjustable, and a lot stronger.
Reactions: MtnManTabernac
Discussion Starter · #16 ·
I went with maxx just for the simplicity. I just wanted to order something bolt it on and go with it. They have great customer service and they have a great product I recommended them. I also just got my fox shocks and they are amazing. The pure size of the shocks are stunning. I got the 2.0's with the external reservoir.
Out with the old, in with the new...
Went with the adjustable Tuff Countrys. Pretty slick, felt nice down the road.
Nice change!
1 - 20 of 24 Posts
