Would need more details. Front end rebuilt? Long bed or short? 4x4? Aftermarket lift pump? Has the VP44 been replaced? AC working correctly? Heater working correctly? Any programmer been used? Have you pulled any codes? 14K would be ok with me if all of those things have been dealt with. But 14K would be on the high end for me as there would many other mods I prefer to get the most out of that year model.
This is what is on the listing and I talked to him and he said there is a slow leak in AC somewhere but that's about the worst or so it seems.
New wheel bearings, CV joints, track bar, brakes,fan clutch, serpentine belt, tensioner pulley and alternator.
Like new E-rated all terrain tires with only a couple thousand miles. Come with a 40k warranty that will go with the truck.
Isspro A-pillar aftermarket gauges
Includes exhaust temp, turbo boost and fuel pressure with low fuel pressure warning.
Air dog Rapter FRRP 150GPH lift pump.
New Bosch VP44 injector pump from Thoroughbred Diesel.
NV 4500 manual transmission rebuilt couple years ago with new synchros, 5th gear fix, tail housing upgrade as well as a new extreme duty clutch.
Banks Power Exhaust Brake
Banks 4-inch monster exhaust
Boost elbow upgrade
Edge EZ tuner with 3 power levels
Truck has been in family over 17 years.
Instrument cluster sporadically shows no-bus message. Will include replacement cluster, but will need odometer programed from Dodge
