1 - 10 of 10 Posts
Just curious. 4000 elevation mods in sig
Discussion Starter · #2 ·
Bd race pro is an edge comp without hot unlock
· Sasquatch
Those twins can support a lot, but you won't have the fuel to fully take advantage of them, that's assuming you have the HO pump and stock injectors. The amount of boost will mostly be dependent on the amount of fuel and the way the turbos are tuned, you might see up to 40 or 45 psi.
No twins yet just have the super b installed
· Sasquatch
35-40 psi should be seen with the Super B, I ran an S256 on my old VP44 truck and saw 43 psi, but that was with an SO VP44. I actually just installed a Super B today to replace the HX40 in the compound set on my 12V, it's a decent little guy.
28 pounds of boost
I can see 35lbs on my HX with only my edge.
· PDRT
The mods on my truck I'm seein tops of 55-60 with the super b special
Sent from my iPhone using AutoGuide.com App
1 - 10 of 10 Posts
