i have done all the deletes on my truck and a smarty
14ME. I the low air pressure light on.....i have checked the tires and they are fine. How do I reset the light? Also when i got my truck out of the shop they put on two new wheels on it, im not sure if they put the pressure sensor back on them....if they didnt how can i delete this light?
· Dont Upset The Hulk....
Put a piece of black electrical tape over it..... :rof:hehe: Just kidding. I would check to make sure that they put the sensors back into the wheels and if they did, run 3psi more than the recommended rating and after the system is reset, you should be good.
..... run 3psi more than the recommended rating and after the system is reset, you should be good.
:ditto:
Had the same problem after I switched to bigger tires. If you don't want to unplug the batteries to reset the computer, just jack the pressure up a couple pounds until the light goes out and it should be okay when you bring the pressure back to where it should be.
ok, thread stealing here, but how do we know if we have this tpms ? I see alot of guys talk about it but i havent ever seen it.
I don't think they put them on the 3500's. Look at your rims, it looks like a weird metal valve stem.
You could always take the bulb out of the guage cluster.
