1 - 3 of 3 Posts
on my 06 how do i adjust or per say tighten it up like on the older gens it had the nut with the set screw in the middle on my 06 it has 2 nuts and i cant see how to adjust it has an allen in the middle if the top nut but it will not turn without turning the top nut thanks guys
Are you trying to straighten steering wheel so it is facing level?
That would be from the Drag Link bolted to it, that will adjust steering wheel and not effect the front end alignment.
Or just tryng to tighted the steering so it doesn't wonder around so much?
im trying to tighten up the steering box if i cant get it to tighten up then its junk. no im not messing with the alighnment thats done by the draglink
1 - 3 of 3 Posts
