1 - 12 of 12 Posts
Ok my 2002 auto cummins is stock from what I can tell...but heres what had me wondering since I got, I put a boost gauge in and Im seeing 28psi. I know these trucks are only supose to go to 20-22 before they defuel..Now im about to put a quad ADR on my truck and I not sure it someone maybe put a smarty/superchips tune on it, and i dont want to add my timing for the Quad box....what can i do to see if theres a tune on it?..I also have scan tools if they will help me find something out.
Thank you,
Hemi
If you want to make sure theres nothing in it the dealership can flash it back to stock.
DieselAutoPower.com
I wouldn't put a superchips on it. I'd think you could hook up a smarty and it'd spit out an error if it's flashed with a tune.
Im not sure if Im going anywhere with this, but is it a possibility that it may have a boost fooler from quadzilla on it somewhere or maybe just a stock truck with a boost elbow that is allowing the higher boost #'s. Not sure if that was a possibility
Hemi
Boost numbers wouldn't go that high unless there's more fuel to spin the turbo.
theres felcrow on my fuse box where someone had a programmer on it but its gone now so that shouldnt be doin it right?
There is velcro on my fusebox too, I have been wondering the same thing. Also looks like I have a temp sending unit on my (manual) transmission and my exhaust manifold is tapped for EGT probe...
I was looking at it today and theres a sticker on my rad suport that says"chrysler aproved something something..and it has TSB programer on it..what is that?
any programmer will override whatever is on it. there can't be two programmers on the ecm at one time
Discussion Starter · #10 ·
If thats true, how do people stack them then:confused013:
1 - 12 of 12 Posts
