1 - 17 of 17 Posts
Banned
I have been wanting to go with 19.5"ers for a while, but cant justify dropping nearly $4000 while im in school. I have looked at the Perelli Scorpion ATR, and would like to know How much bigger a 265 is compared to the factory 235. Also,has anyone run these tires, especially on a dually?
Banned
Width and height...and quality of tire.
I havent ran those brand of tires but 265x70 are pretty close 31X10.50
Banned
I want to go with about a 33" in height.
the pirelli scorpions are a decent tire, but i've never seen them get very good tread wear, pirellis I've noticed tend to have a little bit softer rubber compound
31.6 H x 10.43W is a 265 70-17. according to the math. To figure out a metric tire size: 1. Divide the width by 25.4, this will give you the width. 2. multiply the width by the sidewall %, double that then add the rim height.
EX: 265/25.4=10.433071" wide
10.433071 x .70 = 7.3031497 x 2= 14.606299 + 17=31.606299" tall
Hope this helps some people trying to figure out metric tire sizes!
285 are about 33" tall, my buddy has 315's and they are 34" tall
you will need spacers for sure with the 285's....or at least thats what everyone keeps sayin, i just put new tires on and i went with a taller tire to avoid spacers
I recently added 265/70 17's Cooper Discoverer STT to my 07 dually. No need for spacer, and the look is great. That is a fine tire in the dirt. A bit rough on the rough roads, but they are nice on the better roads. Very little road noise.
How much space between the duals?
I put BF GOODRICH Commercial T/A tires in a 245/75-16 with a 1/4" spacer. These are a great tire so far, I only have about 20k on them but tread depth has not changed even on the fronts.
These are 265/70/17 cooper st's with a 1/4" spacer.
DO YOU EVER TOW "HEAVY" WITH THAT TRUCK BECAUSE I'M PRETTY SURE THAT THEY WOULD RUB IF IT WERE TO HAVE A HEAVY LOAD ON.
yes i have 285/75/16s and i had to have 1/2" spacers(didnt have to but with haulin trailer to close for my comfort)
and they are around 33" if i am not mistakin
someone correct me if im wrong
thats with 1/2" and 285/75/16s like i said
285 are 33s i just put 265/70/17 on my 03 dually and have way more room than rn workshop has between his tires with a spacer but he also runing 285
1 - 17 of 17 Posts
