So I took my truck to get an alignment.. Of course there is stuff worn out so no alignment for me until I get this stuff replaced.. Anyways I'm trying to get it all fixed on one shot, so I'm trying to get a list together of what to replace..
What is definitely worn out is both lower ball joints, and both inner tie rods..
So here's my list, anything ya'll can think of to change while I'm at it?
Lower Ball Joints
Upper Ball Joints
Inner Tie rod ends
Outer tie rod ends
tie rod adjuster things
Pitman arm
idler arm
sway bar end links and bushings
upper shock bushings
Anything else? I've heard the control arm bushings usually don't wear out?
Lower Ball Joints
Upper Ball Joints
Inner Tie rod ends
Outer tie rod ends
Pitman arm
idler arm
